IR 5000 , finisher error 584
  • adel_nathan
    • Jul 2011
    • 103
    hi every body
    i have error in finisher IR5000 ; E584
    i read S.M. and found it's shutter error in sensor or switch
    i clean them carfully , and nothing better
    the error comes when i used stappler over than 34 copies
    but if i do normally job , the machine is very good and no error appear
    if you can help , please send it fast
    thanks
    and sorry because my english is'nt good enough
    bye
  • charm5496
    • 2387
    Re: IR 5000 , finisher error 584
    check your swing gear
    • Canuck
      Tech Specialist
      • 1713
      The one-way clutch inside goes bad. You can try cleaning it and putting a drop of oil inside it. Easy to get at. Just pop off the back cover and its right there.
      • Simons
        • Jun 2008
        • 490
        Check the front offset guide for sticking. Remove the noise reduction foam for solonoid actuation. This was another PITA on this finisher after swing guide had been replaced by someone else. The whole problem was a piece of foam and I do beleive that that was a similar error if not this same one. Something you better check .
        • teckat
          • 16083
          Check the Compression Spring on MSW3, located on the rear frame side of the Finisher, make sure it did not become dislodged. This will prevent the switch from being actuated by the Tray Frame Assembly.
          Installing a new Compression spring on MSW3 the finisher began to function normally. If the spring is installed correctly and is intact, verify the operation of the switch.
          IMG_6385.jpgSpring ,Compression FS6-2564-000
          Micro-switch, MSW3 WC4-5130-000
          If sensor PI-5 is not aligned correctly when the finisher starts up the gate will not open and close. This gives the appearance that the gate motor or sensor is not working when in fact the sensor to the shutter did not change state, causing an E584 code
          Ensure that PI-5 is changing state when the shutter is raised and lowered. This can be checked at J12B-6 on the finisher controller. A change of 5 VDC should occur at this pin location.
          Check the switch on the rear side of the finisher, increase the spring tension and adjust the switch actuator.
          This MS3 switch detects the movement of the of the trays
          • adel_nathan
            • Jul 2011
            • 103
            Thanks for all try give me hand ;
            • Canuck
            thanks Mr. canuck ; but i don't know which one-way clutch do you mean
            please if you can give me PART NO
            • [*=1]simons
            thanks Mr. Simons ; also if you can give me PART No for this solonoid
            • [*=1] teckat
            Thanks Mr teckat ; i will try this and told you
            please if there are any another idea , give me your hand
            bye
            • Simons
              • Jun 2008
              • 490
              figure q38 in F1 parts. fh7-5940. SL6 you can see it in the front. remove foam or dab with grease. Can interfer! Make sure your switchs are ok and dont be afraid to bend the mounts if needed. SL6 connects to the shutter lever.
              • Canuck
                Tech Specialist
                • 1713
                • Canuck
                • [*=1]simons
                • [*=1]teckat
                bye
                Its actually not a gear. Its called Cam,Shutter in the parts manual. Part number is FB3-7298. Item 16 in parts manual,Swing assembly,Figure Q36. The one way is inside it. This is a very common issue on these finishers...same used on irc3200. Pop the e-clip off when you have the back cover off. Can be changed in 2 minutes.
