The touch panel will not detect in the area of the Function button. Therefore I cannot preform the Touchchk function. Is there another way to access this? When I touch a button it seams to actuate the one below it.
Canon irC5870 touch panel adjustment
Re: Canon irC5870 touch panel adjustment
COPIER>FUNCTION>PANEL
TOUCHCHK Use it to adjust the coordinates of the analog touch panel.
Method of Operation
- use it to match the points of press on the touch panel and the coordinates of the LCD.
- perform this service mode if you have replaced the LCD.
1) Select 'TOUCH CHK' to highlight, and press the OK key.
2) Press the symbol '+' appearing on the touch panel in sequence (9 points) to end the adjustment.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
I have a service handbook and already know this. If you would read the post you would see that the touch panel is non-responsive to the area where the function button is located. Based on the fact that when you touch a button it activates the on below it I would have to touch the panel in the middle of the blue plastic frame of the touch panel.Comment
if ok !!!!
Replace Analog Touch Panel=FK2-0246-000
The Analog Touch Panel sits on top of the LCD display is used to feed the controller within the panel with the X and Y coordinates when the panel is pressed upon.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
