Counter Memory PCB & SATA-Flash PCB List
[KEEP PCBs WITH THE NATIVE MACHINE AT ALL TIMES]
see pdf____________
NOTE:
COUNTER MEMORY PCB, SERIAL PCB, and SATA-Flash PCB MUST ALWAYS REMAIN WITH THE NATIVE MACHINE AT ALL TIMES AND NOT CHANGED WITH NEW PCBs AT THE SAME TIME!
E245: The upper limit imposed on writing to the counter memory has been exceeded. * Replace Counter Memory PCB & Clear E355
E246: Counter Memory PCB * Replace Counter Memory PCB
E247: Error in SRAM on Main Controller PCB and Counter Memory PCB. * Replace Counter Memory PCB & Clear E355
E350: Serial Number PCB * Replace Serial Number PCB (Controlled Part)
E354: Mis-Match between Counter Memory PCB, Serial PCB and Main Controller PCB * Place ALL Original PCB's back into machine
E355: Power-on Mismatch between Counter Memory PCB, Serial PCB and Main Controller PCB * Place ALL Original PCB's back into machine
E748: Error in the Flash PCB * Replace the SATA-Flash PCB
see pdf____________
NOTE:
