Hey, Gang. I need the firmware for a Canon ir 1023if. If anyone can help I would appreciate it. Email is bfc@tds.net if needed. Thanks! Also, instructions for procedure.
firmware ir1023if
Re: firmware ir1023if
hello friend have IR1018 - 1020 - 1023 the same Firmware!! if it have, i will send you .A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
DAMENE ABDEL AZIZ
DJELFA
System Software v68.01.01
BootROM v61.01
DCON v9.01**==** Not Upgradable. PCB replacement required.
UFRII LT v68.01-16M iR1023/1023N
Printer Kit-M1 v68.01-32M iR1023iF
Service Support Tool v4.33Ez
<Supplementary information>
If "OK" appears on the touch panel display of the main unit, data transfer has been completed by overwriting the ROM.
<Points to note>
(1) If upgrading from an older version to v60.03 (or later), the BOOT area is increased.
At the same time, the SYSTEM writing start address (FLASH-ROM) is changed.
The SYSTEM writing start address is included in the BOOT v60.03 and later, so after BOOT has completed downloading, turn OFF and ON the power, so that the new SYSTEM writing start address is reflected.
Upgrade procedures
<Without options>
1. Overwrite BOOT.
2. Check that "OK" appears on the touch panel display. Then, turn OFF and ON the power manually.
(Download mode starts.)
3. Overwrite SYSTEM.
<With OPT16MB>
1. Overwrite BOOT.
3. Overwrite OPT16.
4. Check that "OK" appears on the touch panel display. Then, turn OFF and ON the power manually.
5. Overwrite SYSTEM.
<With OPT32MB>
1. Overwrite BOOT.
2. Check that "OK" appears on the touch panel display. Then, turn off and on the power manually.
3. Overwrite OPT32.
4. Check that "OK" appears on the touch panel display. Then, turn off and on the power manually.
5. Overwrite SYSTEM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
