Canon IR2020 problem with E805!! Please help me resolve !!!
Re: Canon IR2020 problem with E805!! Please help me resolve !!!
Get out the ohmmeter, trace the path from dcon to the fan with connectors unplugged. Could be an intermittent intermediate connector(pins on both sides) needs reseating, or a ty wrap pinching something(ir 2020s are old..dry insulation on wiring).Comment
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Good evening,
I solved the fan problem.
Finally the error E805 disappeared.
But now I have another problem ... The dispay tells me that there is paper jam in the left door, but opening all the doors and drawers you can not see any paper. What could be the problem?
Thank you.Comment
Good evening,
Thank you.
What is the Jam Code
Probably a Stationary code = 02xx**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
in service mode check the Jam Codes
Jam history description (JAM)
Item Explanation
[1] Number The larger the number of a jam, the more recently it has occurred.
[2] Jam date Date of jam occurrence
[3] Jam time
[4] Jam recovery time
[5] Location 3: Host machine, 4: ADF, 5: Finisher
[6] Occurrence category 0: Host machine, 1: ADF, 2: Finisher
[7] Jam code = Jam cause
[8] Total counter display
[9] Pickup stage position 0: Manual feed tray, 1: Cassette 1, 2: Cassette 2, 3: Cassette 3, 4: Cassette 4
[10] Paper size
Host machine
0104 Pickup assembly delay jam
0208 Pickup assembly stationary jam
010c Delivery assembly jam
010e Second delivery assembly delivery delay jam
0210 Delivery stationary jam
0212 Second delivery assembly stationary jam
0214 Host machine retention paper jam
1118 Door open jam
0120 Duplexing paper sensor 1 delay jam
0221 Duplexing paper sensor 1 stationary jam
0124 Duplexing paper sensor 2 delay jam
0228 Duplexing paper sensor 2 stationary jam
ADF
0000 Unknown jam
0007 Initial stationary
0008 Read sensor delay jam
0009 Read sensor stationary jam
000a Paper absence (Pull out the document.)
000c Delivery reversal sensor delay jam
000d Delivery reversal sensor stationary jam
000e ADF cover open error
000f User ADF open error
0010 Pickup NG
Finisher
0130 Inlet sensor delivery delay jam
0231 Inlet sensor delivery stationary jam
0033 Bundle delivery jam
0035 Stapler jam
1036 Power-on jam
1137 Door open jam
Error history description (ERR)
Item Explanation
[1] Number The larger the number of an error, the more recently it has occurred.
[2] Error date Date of error occurrence
[3] Error time
[4] Location 3: Main unit, 5: Finisher
[5] Error code Error code (4-digit code; for a definition of the code, see the "Error Code" Chapter.)
[6] Detail code Detail code of the error code (4-digit code; for a definition of the code, see the "Error Code"
Chapter.)
[7] Total counter display**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Good morning guys and thank you for the patience you have shown me ...
I know how to get into service mode (*, 2.8, *), but I do not know how to continue later to check for errors. Could you tell me the procedure?
Thank you.Comment
