ir 2016
  • tecnimatiz
    ir 2016
    I need your help.
    I have a customer with a canon ir2016, when he turn on the display it show "DOWNLOAD STANDBY" and it not start, what happen with this copier.
    thanks.
  • yourownfree
    • Dec 2007
    • 474
    wow! no idea. did someone leave a usb drive in the usb slot? have you tried to unplug the machine for a minute or so then plug it back in? not sure if customer is really turning it off. Doesn't sound good whatever it is.
    sounds like it was in download mode the somebody shut machine off or similar. doesn't hurt to always check the power coming to machine at the outlet for a proper ground, less than a volt from common to ground.
    also i will send you an email with some more help, good luck.
    • nghialuuvn
      • Jan 2008
      • 67
      This issue will be gone after upgrade system software to Ver 61
      Good luck
      • tecnimatiz
        Originally posted by nghialuuvn
        Good luck
        how i can obtain.....
        • nghialuuvn
          • Jan 2008
          • 67
          Pls contact Canon authorised agency near your location
          This software is free to Canon customer
          • _SuabE_
            • Jan 2008
            • 108
            IR2016 System software?
            Can anyone share this system software it will be a great help like us in a remote area.. Thanks in advance..
            sigpic
            Senior Technician Specialist
            A+; Network+
            Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
            Printer Handled: Canon, HP, Epson, Brother, Samsung
            Duplicators: Risograph, Duplo
            • maks
              • May 2008
              • 75
              is it possible to download the system software 61 and share it with me for solving the problem "download" message on IR 2016?cause now im also in the same situation..the canon distributor doesnt want to come to our place for some reason.. when i turn off and on the unit ,sometimes it will go back to its normal operation..thanks for any help to be lend again to me..
              • tristan
                Please Need firmware for canon ir 2016
                Please guys, please I Need firmware for canon ir 2016.
                Is urgent for me. Please help.
                Thanks in advance
                Tristan phaneuf
