Ir 6020i background
  • teckat
    • 16083
    #16
    Re: Ir 6020i background
    Originally posted by Desert Rat
    Problem solved,
    Here's what happen. When I cleaned out the hopper, I had to take some of the
    stuff off the side. Both motors, a plate, some loose gears and a pin.
    I got all this back on ok except for the one flat gear above the small
    motor in the lower right, M10.
    That gear has a collar on one side that spaces the gear off the side
    of the hopper about 1/4". I had it on 180 out. So this gear did
    not transmit movement to the augar gears that bring the toner
    out of the hopper to the developer station like it should have.
    Flipped the gear around now it is off the hopper and meshes
    with the other gears.
    Loaded the DV station with toner and made some nice copies.
    The mag roller looked good. Even & dull looking.
    Turns out the toner I put in this machine awhile ago was
    bad. It was generic toner. I forget who I got it from.
    Thanks for all the suggestions, this board is one of my best resources.
    DR
    backtrack >>>>>>>>>love it
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      #17
      Originally posted by charm5496
      Do you think they might have stuck the wrong toner in the hopper at some point?
      Problem was diagnosed here all along!! 2nd post too.
      I'm sure there is a moral here.
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
      • DAG COPIERS & COMPUTERS
        • Oct 2010
        • 860
        #18
        Well, a very good brainstorming session it was!. Wasn't it? Visit our market here, and you will '' collide'' head on with all types of toners & parts, from OEMs to Generic of Generics, duplicates of duplicates and in worse case scenario triplicate of triplicates. It is a big, long battle our National BUREAU of Standards is fighting here. But life goes on!
        • Desert Rat
          • May 2008
          • 1089
          #19
          I've been at this a long time. I have used some generics in this model for a while. But it only
          takes one problem like this to drive the point home.
          Surprizing to me that I don't run into more problems with generics. I use the oems when
          I can afford them. Of course using the oems avoids a lot of problems. I will just have
          to switch.
          Thanks for all the advice
          DR
