I am having problem with toner supplay on cyan but after trying to test motor none of them will operate (C,Y,M,K) I do have service manual and in it is this
Used to specify motor for operation check.
(Range: 1 to 25; 18 and above are reserved.)
Operation method 1) Select this item.
2) Enter the desired motor code on the numeric
keypad.
1: Drum ITB motor M1
2: Toner container motor (Y) M20
3: Toner container motor (M) M21
4: Toner container motor (C) M22
5: Toner container motor (Bk) M23
Starts motor operation.
Operation method Toner container motors (Y/M/C/K):
1) Remove the toner container, and leave the front cover open and push
the front cover detect sensor with cover switch tool.
2) Select this item, and press the OK key.
- 10 seconds ON -> OFF
Have tried all of them by procedure in SM an they say OK but they do not spin at all. Any help on subject.
keypad.
