canon ir 5570 blur on 2nd side
  • y_us1982
    • Jun 2025
    [Misc] canon ir 5570 blur on 2nd side
    hi..
    i had faced image get blurred on 2nd side when i'm running duplex mode on my ir5570. it get blur only 1/4 page on 2nd side. i wonder what the problem, i had replace all the wires, also had clean the drum but the answer still the same. what makes me thinking is, the blur doesn't get at all the pages, it appears after 8 or 10 piece then it will be ok, then after 8 or 10 piece of paper it will get blur again. anybody had any idea on this situation... hope can hear from all the experties out there. thanks...
  • teckat
    • 16083
    Re: canon ir 5570 blur on 2nd side
    Originally posted by y_us1982
    hi..
    adjust the fixing inlet guide Up 1 mm on both front and rear sides.
    check your steel roller in duplex for wear #25
    Steel roller, (part number FB5-3322-020) along with the washer, item 66 (part number FS5-6488-000) and the bearing, item 78 (part number XG9-0192-000)
    • y_us1982
      thanks teck. i'll reply once i done this suggestion.
