iR C3220N CLC4040 CLC5151 iR C4080i
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Controller Box Assembly
    Due to the manufacturer's production suspension of PATA HDD that is currently used for the models above,
    PATA HDD is switched to SATA HDD.
    As PATA HDD is out of stock because of this, the following actions should be taken.
    If there is a need to replace PATA HDD in the field, use SATA HDD for the replacement.
    clc.pdf
    • 16083
    Re: iR C3220N CLC4040 CLC5151 iR C4080i
