CLC3200
  • Apach
    • 157
    CLC3200
    I have a 2 small problems.
    1. How to make default BW copy (now is color). The setting can not see the option for the primary setting.
    2. When printing PDF file I cant to make order front to back page. Printer always start to print from page 1.
    CLC dont have finisher. I had to manually rearrange nearly 3000 copies. I want to kill controler
    There is no stupid question, just stupid answer
  • charm5496
    • 2387
    Re: CLC3200
    when printing click on the button that says print in reverse order.
    on the default B/W just set your machine up the way you want it to be all of the time for making copies. Then push the (*) additional functions>copy settings>standard settings>store. From there forward that will be your default when you hit reset.
