I changed the gear group of it the was 2 greas broken. The cleaning web dosent move I must move it manually. The sloenoid work.
Help
Replace the black gear (FS7-0045-000) with FS7-0893-000. You should also replace the other web advance gears with the following: FS7-0091-000, FS7-0894-000 and FS7-0895-000.
For best results replace all 4 gears as a set.
Pls note: the OEM Part # you mentioned is not in the service part catalog for this model IR6000
May you mean FS6-0105-000 GEAR, 22T/60T and another gears ?!
Canon FS7-0893-000, FS7-0045-000 they are both the same gear, try not to get the black gear (FS7-0893-000) FS7-0045-000 is different material- updated 9 years ago22T/63T FUSER GEAR
Thanks for this information.
I cahnged all the gear groub (9 greas) and the one way arm and bushing, but it didn't work also the solenoid woks good when I chach it partly (Part-CHK).
are there in thing in the machine program?
