iRA 5030 Uneven Density
  • spectraindo
    • May 2008
    • 313
    Hello everyone, I have a problem with iRA5030.
    The print density at the front and rear edges of the paper is light, at the center is OK.
    It happens on all colours (CMYK), the meter is 9140 prints.
  • 27842
    • Feb 2011
    • 7
    Re: iRA 5030 Uneven Density
    I have worked on IR3880 and earlier color, not sure if the same. Do internal print see what happens, if same look at transfer mabey not sitted properly, laser filters dirty.
    • spectraindo
      • May 2008
      • 313
      Thank you.
      Problem solved, the ITB Sub Pressure Release Lever was not set properly causing the ITB not contacting the drum evenly.
      • charm5496
        • 2387
        good find. I'm sure this will help some others in the future!
