canon ir8070 errorcodeE000602-0413
  • jebaraj
    • Aug 2025
    [Error Code] canon ir8070 errorcodeE000602-0413
    sir i have problem with canon ir8070 errorcodeE000602-0413
  • charm5496
    • 2387
    Re: canon ir8070 errorcodeE000602-0413
    you have a HDD issue on your machine. I would replace the HDD and reinstall the firmware. If you do not have this or know how to do this pay someone who has the tools and skills to take care of it for you.
    • jebaraj
      thanks for your support
      • charm5496
        • 2387
        You are welcome
        • mramlawi
          • Jul 2011
          • 838
          charm always on the bottle he always answer the first no comments :P
          Same Charm answer
          Distinguished road makes you jewel in rough
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            Optimus prime rules!!
            • teckat
              • 16083
              E602-0413
              When the E602-0413 error occurs try to perform the Hard Drive Clears on each partition.
              To perform the HD Clears go into service mode COPIER>FUNCTION>SYSTEM
              Select CHK-TYPE and set it to 1 and press ok.
              Then select HD-CLEAR and press ok.
              Select CHK-TYPE and set it to 2 and press ok.
              Select CHK-TYPE and set it to 3 and press ok.
              Select CHK-TYPE and set it to 4 and press ok.
              After completing this procedure, power cycle the imageRUNNER and reenter any user settings.
              NOTE:
              If the error still occurs format the Hard Drive with the Service Support Tool and re-install the System Software.
