black shade in the top edge , please see the attachment
  • dilip_22
    • Sep 2011
    • 20
    [Misc] black shade in the top edge , please see the attachment
    Hi Friends , Canon iR3235N after installation it is copying black edge.
    please see the attachment, I replaced the new drum unit & checked all the settings, but not ok. some time it coming clear copy if i copy a lot, but after 3-4 hours same thing. please see the sample copy
    thanks
  • ernesto
    • Oct 2011
    • 430
    Re: black shade in the top edge , please see the attachment
    thanks
    Hi
    do you have the same problem when you use this copier like a printer ?
    • dilip_22
      • Sep 2011
      • 20
      thanks for ur reply, no user print list is ok, but copying is the problem. I replaced the drum but not ok, I am thinking to replace ccd flat cable, if same i will replace carriage unit, should i do it? please advise
      • charm5496
        • 2387
        is your document laying flat on the glass?
        is your CCD sitting correctly under the glass?
        Does it do this on stream reading as well?
        • dilip_22
          • Sep 2011
          • 20
          Yes , document position is ok, ccd is moving fine,
          • mramlawi
            • Jul 2011
            • 838
            Hello my friend
            yea man check the ccd its scanner problem cos u said that you made user test and it looks good
            Distinguished road makes you jewel in rough
            • charm5496
              • 2387
              there should be white plastic guides that the scanner moves on. Make sure both the op and non-op guides are in place.
              I would also go through and clean the scanner and run the CCD adjustment procedures before replacing parts.
              • dilip_22
                • Sep 2011
                • 20
                Hi Friends,
                I have replaced the ccd unit with the flat cable & copy is fine.
                Thanks everyone to help me.
                • charm5496
                  • 2387
                  awesome....thanks for the follow up with solution!!!
