Error code C1 E00020-0184
  • copykatprinting
    I keep getting the same error code on the C1 #E00020-0184 i get it after running a few copies. Can anyone help? the technician does not seem to know how to fix it .
  • charm5496
    • 2387
    Re: Error code C1 E00020-0184
    fire your tech and find one that is trained on this device!!! This is either a dirty ATR sensor, failing developer unit or drum
    • copykatprinting
      thank you! he is hissstory!
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Check if you have broken this parts.
        It's behind P-kit unit
        • DANIELCANON
          • Jun 2011
          • 187
          revize el archivo adjunto3TP09-327-S E020 XX84.pdf luego ejecute:
          fuction/dpc/drm-rset. ------------para resetear el tambor.
          fuction/misp-p/pt-lpadj.-----------para ajustar los sensores de cuadros.
