cannon pc745 shows paper jam but there is no paper
  • maccool5
    [Jamming] cannon pc745 shows paper jam but there is no paper
    Could use a diagram or possible suggestions.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: cannon pc745 shows paper jam but there is no paper
    Check pick up assy in your case.
    • Brian8506
      • 1665
      If it allows you to copy but jams, check the paper sensor actuator for a break. If it just shows jam take out bypass and check bypass sensor flag. The flag actuates a sensor on the frame when its in place. If the flag pops out of place it will show a constant jam.
