know solving a error code
  • dr.mansoor
    • Nov 2011
    • 12
    [Error Code] know solving a error code
    Hi.can i know error codes of my meshine (canon ir 105+) and solving them?pls send me a broshor containing all of error code.thanks
  • mramlawi
    • Jul 2011
    • 838
    Re: know solving a error code
    hello Dr .
    you know there alots for error codes for this machine ,you just want to take information or you have an error want to solve it .anayway
    i ll do my best to scan for u some of it .
    Distinguished road makes you jewel in rough
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Send error code please.
      • teckat
        • 16083
        The error codes are grouped as follows according to the items they refer to:
        E000 to E399 error code =related to the copier
        E400 to E499 error code =related to the ADF
        E500 to E514 error code =related to the finisher
        E515 error code =related to the inserter
        E518 error code =related to the paper folding unit
        E530 to E595 error code =related to the finisher
        E5F0 to E5F9 error code =related to the saddle stitch assembly
        E601 to E830 error code =related to the copier
        When the self diagnostic mechanism has gone ON, the machine may be reset by turning its power switch. This, however, does not apply to E000, E001, E002, E003, E004, E005, E013, E020, or E717, indicating a fault which can lead to serious consequences if the machine is reset without removing the cause (i.e., melting thermistor, which will overheat the fixing roller, or overflowing of toner from the hopper).
        -If the code is from E000 to E003, the power switch will go OFF in about 30 sec if it is turned ON without resetting; in the case of E004, the power switch will go OFF in about 3 sec after indicting E000 if the power switch is turned ON without resetting.
        -You will have to clear the data in the RAM on the DC controller PCB for the following: E000, E001, E002, E003, E004, E005, E013, E020, and E717.
        • teckat
          • 16083
          see pdf___iR105 ERROR CODES
          • zoraldinho
            • Mar 2008
            • 5007
            Wery generous!
            • dr.mansoor
              • Nov 2011
              • 12
              hi.thanks dear feiend.for example 000069.
              • teckat
                • 16083
                I just posted u above >an entire pdf of the ERROR CODES descriptions/ did u download it or read it
                http://www.copytechnet.com/forums/at...105-errors.pdf
                E069
                Main cause The HV-DC PCB is faulty. The HV-AC PCB is faulty. The transfer charging assembly is faulty. The wiring is faulty (short circuit, open circuit). Condition
                -0000 An error (leakage) is detected in the high-voltage output to the transfer charging assembly.
                here is a one page pdf for troubleshooting E069
                • teckat
                  • 16083
                  Wery generous!
                  [ATTACH=CONFIG]12911[/ATTACH]
                  iR105 Troubleshooting.pdf
                  • dr.mansoor
                    • Nov 2011
                    • 12
                    okkk.very very thanks.very gooddd.
                    • dr.mansoor
                      • Nov 2011
                      • 12
                      COPIER>FUNCTION>CLEAR>ERR). were is this pathway?in setting in my meshine?pls tell me step by step.tanks
                      • zoraldinho
                        • Mar 2008
                        • 5007
                        add func.jpg.....28At the same time.......add func.jpgCOPIER>FUNCTION>CLEAR>ERR>OK
                        Restart
                        • teckat
                          • 16083
                          Are u a tech ???
                          be careful what u touch in service mode/ it can make your machine inoperable to use
                          • dr.mansoor
                            • Nov 2011
                            • 12
                            Originally posted by teckat
                            Are u a tech ??? ** be careful what u touch in service mode/ it can make your machine inoperable to use [ATTACH=CONFIG]13034[/ATTACH][ATTACH=CONFIG]13035[/ATTACH][ATTACH=CONFIG]13036[/ATTACH]
                            hiii.very very tank u.can i found an error history?a list of previous errors of my meshine.that contain all of errors'solved or not solved.
                            • zoraldinho
                              • Mar 2008
                              • 5007
