know solving a error code
  • zoraldinho
    replied
    Re: know solving a error code
    Originally posted by dr.mansoor
    hiii.very very tank u.can i found an error history?a list of previous errors of my meshine.that contain all of errors'solved or not solved.
  • dr.mansoor
    replied
    Originally posted by teckat
    Are u a tech ??? ** be careful what u touch in service mode/ it can make your machine inoperable to use [ATTACH=CONFIG]13034[/ATTACH][ATTACH=CONFIG]13035[/ATTACH][ATTACH=CONFIG]13036[/ATTACH]
    replied
    COPIER>FUNCTION>CLEAR>ERR). were is this pathway?in setting in my meshine?pls tell me step by step.tanks
    Are u a tech ???
  • zoraldinho
    replied
    add func.jpg.....28At the same time.......add func.jpgCOPIER>FUNCTION>CLEAR>ERR>OK
    Restart
  • dr.mansoor
    replied
  • dr.mansoor
    replied
    okkk.very very thanks.very gooddd.
    replied
    Originally posted by zoraldinho
    Wery generous!
    [ATTACH=CONFIG]12911[/ATTACH]
    iR105 Troubleshooting.pdf
    replied
    hi.thanks dear feiend.for example 000069.
    I just posted u above >an entire pdf of the ERROR CODES descriptions/ did u download it or read it
    http://www.copytechnet.com/forums/at...105-errors.pdf
    E069
    Main cause The HV-DC PCB is faulty. The HV-AC PCB is faulty. The transfer charging assembly is faulty. The wiring is faulty (short circuit, open circuit). Condition
    -0000 An error (leakage) is detected in the high-voltage output to the transfer charging assembly.
    here is a one page pdf for troubleshooting E069
  • dr.mansoor
    replied
    Send error code please.
  • zoraldinho
    replied
    Wery generous!
    replied
    Hi.can i know error codes of my meshine (canon ir 105+) and solving them?pls send me a broshor containing all of error code.thanks
    see pdf___iR105 ERROR CODES
    replied
    The error codes are grouped as follows according to the items they refer to:
    E000 to E399 error code =related to the copier
    E400 to E499 error code =related to the ADF
    E500 to E514 error code =related to the finisher
    E515 error code =related to the inserter
    E518 error code =related to the paper folding unit
    E530 to E595 error code =related to the finisher
    E5F0 to E5F9 error code =related to the saddle stitch assembly
    E601 to E830 error code =related to the copier
    When the self diagnostic mechanism has gone ON, the machine may be reset by turning its power switch. This, however, does not apply to E000, E001, E002, E003, E004, E005, E013, E020, or E717, indicating a fault which can lead to serious consequences if the machine is reset without removing the cause (i.e., melting thermistor, which will overheat the fixing roller, or overflowing of toner from the hopper).
    -If the code is from E000 to E003, the power switch will go OFF in about 30 sec if it is turned ON without resetting; in the case of E004, the power switch will go OFF in about 3 sec after indicting E000 if the power switch is turned ON without resetting.
    -You will have to clear the data in the RAM on the DC controller PCB for the following: E000, E001, E002, E003, E004, E005, E013, E020, and E717.
  • zoraldinho
    replied
  • mramlawi
    replied
    hello Dr .
    you know there alots for error codes for this machine ,you just want to take information or you have an error want to solve it .anayway
    i ll do my best to scan for u some of it .
  • dr.mansoor
    started a topic [Error Code] know solving a error code
