replaced main controller,machine was powering on @ off intermittently,controller fixed the problem,however now wont scan doc.s to server or rx doc.s to file either,both go to the same file,what should i do. It does have universal printer kit. Was working before replaced main controller,been trying to reestablish conn to server but user name and passwords im trying arent working and cust doesnt know them either
canon ir4570 wont scan documents to server
Re: canon ir4570 wont scan documents to server
you need to re-establish those connections to the server from the copier with the proper username and password to acces the shared folders.Accidents don't just happen. They must be carelessly planned. -
Are you Canon autoriesed tech?If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
Did u put back in your P PRINT & USER PRINT settings ?????**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Last edited by teckat; 11-15-2011, 02:54 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Accidents don't just happen. They must be carelessly planned.Comment
XCanonTech
Hi Kevin, can you browse the network from the scan tab?Comment
