uniflow
  • TEC DOG
    • Sep 2011
    • 113
    uniflow
    Is it posible to disable uniflow in service mode to have regular copier? I'm familiar with comp. way.
  • vigour
    • Aug 2010
    • 1038
    Re: uniflow
    you have to log into SMS and disable the service.
    this might work::::
    go to additional functions>system settings>initialize all data settings. This will take your machine back to factory default and clear all customer settings from the machine
    • charm5496
      • 2387
      Re: uniflow
      this might work::::
      doing this will clear out the MEAP applications, but you will not be able to restart them afterwards at all. If you want to disable the MEAP app then you have to log into the SMS through the RUI and stop the service.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Re: uniflow
        this might work::::
        You can't go to additional functions if machine have uniflow installed.
        • vigour
          • Aug 2010
          • 1038
          Re: uniflow
          That is true only if you cannot log in.
          After logging in we should be able to get to additional functions, and other necessary areas.
          • zoraldinho
            • Mar 2008
            • 5015
            Re: uniflow
            Probably don't have login code and asking for solution in service mode.
            • charm5496
              • 2387
              Re: uniflow
              Question :
              What is the correct Login and Password to access the Service Management Console { SMS } on a MEAP device?
              Answer :
              Access the Service Management System Console {SMS} on a MEAP device from Internet Explorer. The correct Login and Password are :
              SMS Login: http:// Device IP Address:8000/sms
              Default password: MeapSmsLogin
              • zoraldinho
                • Mar 2008
                • 5015
                Re: uniflow
                Like hi say,it's informed with this solution,but hi won't to know about magic button in service mode to turn OF/ON MEAP aplication,I guess!?..
                • charm5496
                  • 2387
                  Re: uniflow
                  see attached tech pubs>>>
                  TP04 152.pdf
                  TP05 042.pdf
                  • Van Steal
                    • 177
                    Re: uniflow
                    Hi Guys, I have one that can't connect to the network.When I turn on the ir3225 I goes into meap and trys to connect with the server but it will not as it is not on a network. I need to change the ip address but if I try to login via sms it asks me to login but after putting the code it will not login. Is this because it can't "connect to server" Therefore I can't stop the client which I will then be able to change the ip address. Any idea's?
                    • zoraldinho
                      • Mar 2008
                      • 5015
                      Re: uniflow
                      Last option:Format...
                      • charm5496
                        • 2387
                        Re: uniflow
                        it doesn't sound like you are going to use the MEAP application anymore so hook up to your SST and format the HDD and reload, if that doesn't work pull the HDD out and connect it to a PC and format it that way first and then reload everything with your SST. You could also get into service mode and try doing an MMI clear followed by a MN-CON clear, but if you do not have the p-prints I would not recommend this procedure.
                        • Van Steal
                          • 177
                          Re: uniflow
                          Thats what I was thinking, Didn't have the software disk with me today
                          • Van Steal
                            • 177
                            Re: uniflow
                            Thanks charm, No he isn't going to need Meap so I'll give this a go if HDD format with SST doesn't work.
                            • TheCanonTech
                              Re: uniflow
                              The only reason that you can't login to the SMS webpage would be if the default password has been changed previously.
                              You then really only have 2 options:
                              The complete format mentioned earlier may work but the proper way would be to contact your local Canon NSO and ask them to provide the MEAP Switch File.
                              After typing in an incorrect password, the device gives you the option of uploading a switch file. This will reset the password to the default and allow you to access the SMS and de-activate uniFLOW.
                              There is no simple 'off-switch' in service mode for uniFLOW.
                              Level 2> MEAPSAFE can help in some situations, but turning off UF Login Manager via the webpage is the best way.
                              If the device has been moved to a different network without without turning UF off first or if DHCP is on and you can't find it on the network anymore, then powering on the device in 'Fixed IP' mode and using a crossover cable to access the webpage will work.
