After replacing the fixing unit (used,but good).I can't get rid of the error code E 008.I went to the service mode COPIER>COUNTER>MISC>FX-UP-RL,entered 0. I even tried clearing the error code in service mode.What am i doing wrong?
Canon IRC3100 / E008
Re: Canon IRC3100 / E008
Problem :
The error code E008-0001 could not be cleared. The code is for the fixing roller reaching its upper limit. After replacing the fixing roller the counter was reset in service mode COPIER>COUNTER>MISC>FX-UP-RL. The code did not clear.
Solution :
In this case the counter PCB was removed, cleaned and reinstalled. The error code was cleared.Accidents don't just happen. They must be carelessly planned. -
If you replaced the existing assembly with a used one, be sure to enter the counter reading of the used fixing assembly using the following service mode item:
COPIER> COUNTER> MISC> FX-UP-RL
If the counter reading is faulty, make the following computation, and enter the result:
A = current reading of 'total 2'.
B = reading of 'total 2' recorded for the previous service visit.
C = reading of 'FX-UP-RL' or 'DV-UNIT-K' recorded for the previous service visit.
Enter the result of the following for 'FX-UP-RL' or 'DV-UNIT-K':
(A - B) + C**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Hi;
is the same code for IR6800cn caused by counter too, cause i cleaned the error and nothing happened and again cleaned error & west toner counter them /c works OK.?Comment
Problem :
E008 0001 - This error code indicates an error in the count of the fixing assembly life. The counter may have become corrupt or the counter was not cleared at the time of parts replacement of upper fuser roller.
Solution :
Check the condition of the upper fuser roller. Replace if the roller is worn or damaged. After replacing the fuser roller, clear counter in service mode. COPIER>COUNTER>DRBL-1>FX-UP-RL.
Turn the power off and then back on at the main switch, following proper shut down procedure.
If the fuser rollers appear to be in good condition, clearing the error code is the same as during replacement and COPIER>COUNTER>DRBL-1>FX-UP-RL, should be cleared and the machine powered off and then back on at the main switch, following proper shut down procedureAccidents don't just happen. They must be carelessly planned.Comment
