ir c3200 black screen
  • pontiac
    • 420
    Have a problem that is new to us . Copier will come to ready and when you press the copy button the screen goes blank and the data light flashes no paper feed or paper comes out about 3 inches and stops. No error code or jam code code you have to power off and back on to reset. When in service mode i can select my funtions i want to test or change but anything that requiers paper feed causes the blank screen issue. I disconnected all the options and tested , same problem. Any and all suggestions are appreciated. Thanks.
  • charm5496
    • 2387
    Re: ir c3200 black screen
    there could be many solutions to this issue.
    I have one question first. Do you have an imagepass attached or did the machine have one attached at some point?
    I would start by reseating the DIMM's and Boot ROM on your main controller. Maybe doing a main controller clear and re-entering your door specs. If you still have the same issue after that I would move to replacement of the main controller and/or DC controller (Main Controller FG3-2854-000 DC Controller FG3-3011-000)
    You could also have a pinched wire in a harness, bad fuse PCB, door switches shorting out above the fuser assembly. All kinds of possibilities.
    • pontiac
      • 420
      It does have a fiery.
      • sgcopiertech
        you can also check the distribution board assembly FG6-9676-000
        • pontiac
          • 420
          It was the distribution pcb. I think it has another name also but who cares it fixed the problem. Thanks a million for the feedback.
