i am working on ir 2200 .i have crooked image .if i make 20 copies from single page it start with normal and get crooked as it goes toward the end. it does same thing on print as well .please share any information if some one ran through this problem. thanks
ir 2200
Re: ir 2200
check your paper guides in the cassette to make sure they are snug against the paper. Check for any torn or jammed paper in the paper path. Try other trays and the stack bypass to see if you experience the same issues from those sources.Accidents don't just happen. They must be carelessly planned. -
Re: ir 2200
did you check the feed rollers??? and also check the vertical guide rollers there is a white roller with a spring that runs throw the middle of the roller some times the hooksthat hold the spring brakes ... wite roller are between feed rollers and guide roller in th feed unit..Comment
Re: ir 2200
check for nicks or burrs in the plasitc guides. If you run it with the door open can you see the paper being skewed as it is going across the transport? What shape is your registration roller and bushings in? are they moving freely? What about your paper guide at the reg roller? is it bent pinching the paper?Accidents don't just happen. They must be carelessly planned.Comment
Re: ir 2200
You might want to remove the drum and shine a light along the registration roller. There is a spring that keeps tension on the registration roller and it's pressure roller ( on top of it). The other day I had one that was skewing and the rear spring that sits on the bushing was gone, so no pressure in the rear, but if this is your problem, then you will see a gap toward the rear because there isn't pressure. Might want to check it.Comment
