CLC 3200 Printer Controller Problem
  • goldencup
    • Nov 2008
    • 366
    Hi, I have units here CLC3200 all with a 128MB Printer Controller and its working okay. I try to use a Printer Controller with 256MB on one of the unit, when I touch the Printer tab, the screen show "Wait a moment. (Check the power source of the print server behind the main unit and cable connection if the display does not change in a moment.)"
    Actually I have not yet used a 256MB Printer Controller so i'm not sure if it is for that model (CLC3200)
    What I noticed is that the red LED is displaying a 00 number, i don't know if its normal
    Is there maybe an adjustment to be done so that the 256MB Print Controller will function?
    Any idea what to check or adjust on the unit?
    attached here are images of 128MB and 256MB Printer Controller:
  • KL568
    _
    • Feb 2011
    • 324
    Re: CLC 3200 Printer Controller Problem
    The one without LED is known as Fiery C1 and if my memory is correct, it will hook up to a CLC3200 or CLC3220. The other is known Fiery C2, i think it will only work with a CLC3220. Our region's these copier are known as iRC3200 / iRC3220.
    The max memory for C1 is 512 / C2 is 1024 but you need to re install the system OD of Fiery. This is not offically supported
    Hope these help you.
    • goldencup
      • Nov 2008
      • 366
      Thank You very much!
