IR 3300 E002 / E000 ..
  • Copyjaya
    • Oct 2011
    • 59
    [Error Code] IR 3300 E002 / E000 ..
    IR 3300 keep appear E002 error code , been clear ERR quite many times ..
    I've change the Heater Element 2 times .. also change the heater unit ( the black part that heather element sit onto ) 1 time .. this morning E002 appear again .. clear error again
    Any other parts need to change again ? please help ..
  • Copyjaya
    • Oct 2011
    • 59
    Re: IR 3300 E002 / E000 ..
    is it possible caused by power supply board ?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5018
      If you have too much power line noise.
      <Symptom>
      E000/002/003/261/733 may occur when connecting the machine with power source having much noise, such
      as a private power generator
      <Cause>
      The power line noise prevents the normal operation of zero cross signals, causing poor control of power supply
      to the fixing heater.
      <Factory Measures>
      New type of switching regulator PCB is used to decrease the effect of power line noise.
      try to change Switching Regulator PCB (FH3-2614-020 ) ..old-FH3-2614-000
      Check version of system software
      iR3300 Ver.11.01
      1)Countermeasure for E002
      2)Modification of the temperature adjustment control for free
      size paper
      3)Multi-purpose tray for B6 size (out of specification)
      supported
      4)Modification of the problem for the service mode
      (REGIST) performance
      5)Modification of the problem for the service mode (TRYSTP)
      performance
      • Copyjaya
        • Oct 2011
        • 59
        im sorry .. i dont have the reference which one is the Switching Regulator PCB..
        Please advise .. ?
        • zoraldinho
          • Mar 2008
          • 5018
          Please advise .. ?
          Start with system software.Probably you also don't have software.
