Hi again everyone, at last our machines ir7095 arrived at our warehouse. There are nearly new machines and everything looks ok. When we attached the sorter to each main body most of them cant detect the sorter at service mode there and the I/O shows in all zero. Without the sorter they can run with no problem. What im thinking is may be the previous users using the machine without sorter together while they loading the firmware to it. Something should i do to detect the sorter? Should i reload the newest firmware? Does this model come with different finisher firmware that we need to load seperately?
Ir7095 nightmare
Re: Ir7095 nightmare
Any errors? E00711-001?
"Cannot recognize finisher"??If it ain't broke, don't fix it
A picture is worth a thousand words -
the finisher has it's own power switch, on top.
you have to power on the finisher on first, count to 5 then power on the copier .
powering off off goes the opposite way.
make sure the circuit breakers at the back are in the right position and make sure the BNC connectors are attached.Comment
Have you try and look under "Acc" in Service Mode Level 1 & 2? You will need to set from "0" to "1". Sorry, This is the best I can provide, as I had seen 1 of my guys done it. With the service manual, you would be much better off.Comment
you also have to go into service mode and tell it there is a finisher after connecting power and communication cables. Make sure that the T-connector and terminators are in place as well.
copier>option>acc-d>acc1-8 enter the number of the finisher in relation to the machine. If it the only thing attached then it would be a 1. see installation guide>>>FINISHER V1-V2.pdfAccidents don't just happen. They must be carelessly planned.Comment
copier>option>acc-d>acc1-8 enter the number of the finisher in relation to the machine. If it the only thing attached then it would be a 1. see installation guide>>>[ATTACH]12999[/ATTACH]
I thought he was crazy.Comment
There's no error code coming out, everything was in position including the T-shape connector. The top finisher power switch was always on before we turn on the beast. Will check on service mode either it's set to 0 or 1 to indicated the finisher and will follow the instruction for turning off and on in order. Will see where does it went wrong.
The other thing is tray 1 and 2 was display as LTR even we adjusted manually the tray size to A4. I know it something to do inside service mode but who can tell me? I'm sorry still processing the purchase of SM.Comment
The other thing is tray 1 and 2 was display as LTR even we adjusted manually the tray size to A4. I know it something to do inside service mode but who can tell me? I'm sorry still processing the purchase of SM.Accidents don't just happen. They must be carelessly planned.Comment
copier>option>cst>p-sz-c1 and c2 set to 6 for a4you also have to go into service mode and tell it there is a finisher after connecting power and communication cables. Make sure that the T-connector and terminators are in place as well.
copier>option>acc-d>acc1-8 enter the number of the finisher in relation to the machine. If it the only thing attached then it would be a 1. see installation guide>>>Attachment 12999
Thanks Herrmann, thanks guys ^^ ya guys roxxxComment
Charm is right, nearly undestroyable. I hope the the new adv 80xx series will work as well...time will tellIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
Canon is still working the bugs out on the 8105 series. Have fought some fun waste toner issues already, and the fuser clips breaking. Other than that things are working alright so far with themAccidents don't just happen. They must be carelessly planned.Comment
Do you mean e013 and backing up in the feedscrew although the bottle is not full?Comment
