canon ir 105
  • marty
    • Aug 2025
    [Misc] canon ir 105
    right paper deck not lifting lift moter good am i looking at dc controller or something else i may be missing
  • watson
    • Sep 2009
    • 64
    Re: canon ir 105
    If you pull the tray out and actuate the lever in front, do you see the lift motor turn? If so, you may need to do do a little reforming on the bracket that pushes down the arm on the front of the tray when inserted.
    • marty
      Re: canon ir 105
      am off this week had a guy do that and motor does not turn if you put the motor in deck two it works what turns the motor on is it the dc controller?
