canon IR 2520 Network Problem
  • mramlawi
    • Jul 2011
    • 838
    Dear friend i have Canon IR2520 at my client and its connected network through a hub and 3 notebooks workin alright on it but they bring another one and define it to print from it .it doesnt work there's ping between the router and the notebook and everything okay.couldnt understand why its not print (using XP PRo service Pack3) canon driver version 2050 UFRII try to install the same driver on other pc same pro,aslo i connected it directly through cross cable same problem any solution ?
    Distinguished road makes you jewel in rough
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: canon IR 2520 Network Problem
    Come again ?????
    • mramlawi
      • Jul 2011
      • 838
      • gensys
        • Jan 2011
        • 323
        Originally posted by mramlawi
        check all IP, check firewall options, uninstall & install URF II Drv., check iR printer port number
        The Road will be Mastered by >>> the Going...
        • mramlawi
          • Jul 2011
          • 838
          Dear Friends
          i want to told u that the Problem is Solved when i tried to install the lastest driver from Canon
          really it made me feel mad ,cos the crazy thing that it works at 2 destops at the same version tried to define the thrid and the fourth one didnt breath there;s Reply but couldnt print
          thanks for ur support
