Canon MF4450 with an e225-0001
  • ironpsur2000
    • 19
    [Error Code] Canon MF4450 with an e225-0001
    I have a customer with a couple of these things, and one of them has an E225 code. Im guessing it is the cis, since i havent seen it yet. Here is my question does anyone have an idea of what this part retails for and a part number would be helpful.
    thanks in advance
  • charm5496
    • 2387
    Re: Canon MF4450 with an e225-0001
    thanks in advance
    E225 is usually related to the scanner and/or scan lamp depending on the subcode. I do not work on this series machine, but Canon is pretty consistent with their error codes and solutions across models.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      E225 0001
      Light intensity of a lamp is
      less or equal to the criteria
      When the same error repeatedly occurs after several
      times of turning the power OFF/ON, execute the
      following remedies.
      (1) Check the connection of Flat Cable between Main
      Controller Board (J5) and Contact Sensor.
      (2) Replace the Flat Cable between Main Controller
      Board (J5) and Contact Sensor........................................FK3-1160-000
      (3) Replace the Contact Sensor......................................FK3-1153-000
      (4) Replace the Main Controller Board...............................
      FM4-7282-000 MAIN CONTROLLER PCB ASS'Y MF4453 MF4452 MF4450 EXCEPT JP,CN
      FM4-7283-000 MAIN CONTROLLER PCB ASS'Y MF4450 JP
      FM4-7171-000 MAIN CONTROLLER PCB ASS'Y MF4450 CN
