scaner for image runer
  • DANIELCANON
    • Jun 2011
    • 187
    hola a todos qiero saber si hay alguna forma de escanear documentos sin utilizar el newtwork scan gear;porque este programa no me funciona con una ir 5075. enviar respuestas please.
  • teckat
    • 16083
    Re: scaner for image runer
    hi all qiero know if there is any way to scan documents without using the scan newtwork gear, because this program does not work for me with a go 5075. Please send responses.
    Universal Send Kit-
    The Universal Send Kit enables you to send scanned documents via e-mail or I-fax, as well as send scanned data to be stored in file servers or User Inboxes.
    To use the Send function, the Universal Send Kit must be activated.
    Network Scanning*
    The Network Scan function enables you to use the iR5075/iR5075N/iR5065/iR5065N/iR5055/iR5055N
    as a conventional scanner. You can scan a document using the machine, and read the data in
    an application you are using on your computer.
    To use this function, the machine is required to be connected to a network, equipped with the Printer
    function (standard-equipped for the iR5075N/ iR5065N/iR5055N), and Network ScanGear* to be
    installed on your computer. You can scan images of up to A3 in size at a resolution of 600 x 600 dpi.
    UFR II/PCL Printer Kit
    The UFR II/PCL Printer Kit supports not only UFR II, but also PCL emulation printing solutions.
    โ€ข To use the features of the UFR II/PCL Printer Kit, it must be activated by registering a license key.
    โ€ข The UFR II/PCL Printer Kit is standard-equipped for the iR50775N/iR5065N/iR5055N.
    PS Printer Kit
    The PS Printer Kit supports PS emulation printing solutions.
    To use the features of the PS Printer Kit, it must be activated by registering a license key after the UFR
    II/PCL Printer Kit (standard-equipped for the iR5075N/iR5065N/iR5055N) has been activated.
    Network Multi-PDL Printer Unit
    Network Multi-PDL Printer Unit is a freestanding printer controller which supports Adobe Genuine
    PostScript 3 and PCL5e/PCL6, and is suited for office environments in which larger print volumes are
    frequently processed. It is also suited for users who use Adobe PostScript or other PostScript
    applications
    Network Multi-PDL Printer Unit cannot be used with the optional UFR II/PCL Printer Kit or PS Printer
    Kit.
    Kit Universal SendEscaneado enPS kit de impresora
    Multi PDL para Impresora en la Unidad de
    • DANIELCANON
      • Jun 2011
      • 187
      gracias teckat si te entiendo. la maquina cuenta con la opcion universal send.
      podrias enviarme informacion sobre el modo de configuracion o un ejemplo como realizar esta opcion de la maquina.gracias.
      • teckat
        • 16083
        teckat thanks if you understand. The machine has the option to send universal.
        could you send me information on how to setup or an example how to do this option from the maquina.gracias
        ? hacer u haber Scan / Enviar la ficha del panel de control!
        Abra las dos y Lee
        READ>>>>>>>>>>iR5075_SEND_FAX Guide.pdf
        READ>>>>>>>>>>>>>
        • DANIELCANON
          • Jun 2011
          • 187
          Muchas gracias ya puedo escanear documentos con el universal send
          sin problemas. El network scangear no me funciono.
          • teckat
            • 16083
            eres bienvenido
