imageRUNNER/imageRUNNER ADVANCE/imagePRESS
Points to Note when Replacing the Main Controller
The SRAM of the Main Controller PCB contains management information of the Inbox data.
If the Main Controller PCB is replaced without backing up the SRAM data, a management information
mismatch will occur and the Inbox data stored on the HDD is initialized.
In the same way, executing service mode level 1 > COPIER > FUNCTION > CLEAR > MN-CON clears
the Inbox management information stored in the SRAM and the Inbox data is initialized.
see PDF>>>>>>>>>>>Points to Note when Replacing the Main Controller.pdf
