Servidor t1 para imagen press c1 me esta volviendo loco.
  • DANIELCANON
    • Jun 2011
    • 187
    • 16083
    Re: Servidor t1 para imagen press c1 me esta volviendo loco.
    Hi all long time ago and I have a problem with the T1 servers which are disconnected from the network every time you send a file from any program. I will be more detail to see if anyone can help:
    T1 install the driver for version 1.0, and also provided with the version 2.0 of the canon website and installed without problems.
    The work station is recognized comand normal.
    The problem starts when I go to print a file at the time of changing the printing preferences (paper type, paper source, paper size, etc..) is there in that moment that the comand work station message indicates the connection loss with T1. The connection will recover after about a minute re-enter the work station without problem comand and leaf prints.
    the server is to be disconnected and reconnected every time you print shipping occasions sometimes in the machine code E747.
    GOOD when I use the PCL5e printer driver solves the problem but such occasions driver RGB color prints that are not real, it is not and does not have Postscript CMYK.
    I've noticed that on some computers operate normally with the ps driver, and other communication is lost. I have to reformat a computer and then installed the driver version 1.0 and has no problems.
    you can have the computer for such occasions problema.LA Connectivity is through TCP / IP.
    OTHERWISE THERE THIS SERVER CONNECTIVITY WITH THE COPY.
    ANY HELP THANKS TO TODOSSSS.
    1. Quitar SDRAM de la PCB principal controlador.
    2. Limpie el terminal de SDRAM con pelusa de papel impregnado con alcohol, y luego volver a colocar la SDRAM.
    1. Remove SDRAM from the Main Controller PCB.
    2. Wipe the terminal of SDRAM with lint-free paper impregnated with alcohol, and then re-fit the SDRAM.
    TELL CUSTOMER
    When shutting off copier with an imagePASS T-1 installed, check that the T-1 is completely off ( no display on the LED screen) before copier is turned back on.
    If the machine is dropping from the network, it may be for some other reason. The best way to test this is to ping the machine while it is powered up. If the correct response is received, proceed to test the machine while it is in sleep mode. You may go into the timer settings and select the amount of time before the machine goes into sleep mode. Once the timer selection is set, wait for the machine to go into sleep mode. Try to ping the IP address of the imageRUNNER. You should get a reply from the network card even though the machine is in sleep mode.
    • KL568
      _
      • Feb 2011
      • 324
      Good translation, teckat
      DANIELCANON,
      If your Fiery T1 system firmware is on Version 1.0, think you need this patch.
      • DANIELCANON
        • Jun 2011
        • 187
        Gracias a ambos voy a ejecutar sus consejos ojala se solucione..... Les informare sobre el asunto.
        • DANIELCANON
          • Jun 2011
          • 187
          HELLO KL568 could explain these last steps to carried out more details please:
          1. Update Info
            • 16083
            1. Update Info
            • DANIELCANON
              • Jun 2011
              • 187
              Excelente muchas gracias....se soluciono el problema con el parche.
              ESTE PARCHE ES SOLO PARA LA VERSION 1.01 porque en los servidores con la version 2.0 no es necesario ya que no ocurre este problema.
              tengo el sistema de restauracion de la version 1.01
              no tengo el sistema de la version 2.0; como puedo conseguirlo lo tendran ustedes ........... gracias de todas formas logre solucionar mi problema.
              GRACIAS.
                • 16083
                GRACIAS.
                Excellent thank you very much .... the problem was solved with the patch.
                This patch is ONLY for version 1.01 on servers with version 2.0 is not necessary because this problem does not occur.
                I have the system restoration of version 1.01
                I have no system version 2.0, as I can get it as you will have ........... thanks anyway solves my problem.
                THANKS.
                Patch provided by KL568 -- I only gave direction--
                good luck
