canon ir 3300 wait problem
  • hari_4848
    • Jul 2008
    • 91
    Canon ir 3300 says "wait" on the screen.
    I switched on and off the copier many times but of no use.
    We found the problem is on the DC controller board.
    Need help to fix it.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: canon ir 3300 wait problem
    First replace dimm with new one....
    DIMM ASSEMBLY-FG3-1620-110
    upgrade DC-Controller
    Check error code history.
    • jrgf67
      • Feb 2010
      • 37
      try replacing the hard disk
      • hari_4848
        • Jul 2008
        • 91
        the HDD is perfectly OK, have cheked it .
        the problem is with the Dc controller ,im quizzed which component is faulty in in the board..
        • vigour
          • Aug 2010
          • 1038
          wait : reload system software (first option).
          • teckat
            • 16083
            Verify that the DIMM on the DC controller is mounted securely and is registered in service mode. Service mode>Copier>Display>Version>DC-CON.
            If the imageRunner has a Fax Kit installed, check to see if the version of the Fax firmware is displayed in Service Mode (* 2 8 * > Copier > Display > Versions)
            If the version for Fax firmware is ghosted out, try disconnecting the Fax Board from the Main Controller. If the imageRunner then boots up fine with the Fax Board disconnected, try replacing the Fax Board.
            or try>>>>>>>>>>>>>>>>
            if on-----------
            Disconnect the Paper DecK L-1, if the ImageRunner boots properly check for a bind in the Paper Deck L1.
