Canon ir6000 copying problem
  • JaguAhir
    • Nov 2011
    • 2
    hello friends help me
    Canon ir6000 continue copying bat this matter missing in white lines
    find attach image
  • urangsunda
    • Nov 2011
    • 13
    Re: Canon ir6000 copying problem
    find attach image
    [ATTACH=CONFIG]13138[/ATTACH]
    Check drum
    **we big family, yayrahmah ... special thank to bpk jonih/ibu**
    • Brian8506
      • 1665
      What have you done so far?. What size paper? Lines in feed or cross feed direction? Coronas are a good place to start.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        3.10 The print has white spots (vertical)
        3.11 The print has white lines (vertical)
        Reader unit
        1) Does the problem occur only in copy images?
        YES: The cause is in the reader unit. Check the following:
        1. Standard white plate (back of copyboard glass) for dirt
        2. Execute the following in service mode:
        COPIER>FUNCTION>CCD>CCD-ADJ.
        3. Execute the following in service mode:
        COPIER>FUNCTION>CCD>SH-PS-ST.
        Fixing assembly
        2) Generate test print TYPE [00]. Turn off the main power switch immediately
        before the paper enters the fixing assembly, and check the image. Is it
        normal?
        YES: The cause is in a process after the fixing system. Check the following:
        1. Fixing assembly upper roller for offset
        Photosensitive drum
        3) Are there scratches in the peripheral direction of the surface of the photosensitive
        drum that match the image?
        YES: Find out the cause of the scratches, and replace the photosensitive
        drum.
        Developing assembly
        4) Is the surface of the developing cylinder coated with an even layer of
        toner?
        NO: Check the edge of the blade of the developing assembly for paper
        lint or the like.
        Transfer/Separation charging assembly, Pre-transfer charging assembly
        5) Clean the pre-transfer charging assembly and the transfer/separation
        charging assembly. Is the problem corrected?
        YES: End.
        NO: Try changing the setting of the following in service mode:
        COPIER>OPTION>BODY>FUZZY.
