Hello,
My office just purchased an Image Press to help with the high volume of in house print jobs we process.
We have be experiencing an ongoing issue that our tech support does not seem to think is a big problem, but it is!
On some PDF files, the printer will produce a line, very straight and uniform across the page in the same spot on each page. We have the the tech support out 3 times to look at the problem and so far it has not been fixed. They have checked the imaging drum, and have concluded that it is a file problem, so the last time they were here they suggested using the smoothing feature on the print driver. Well that is no longer working as I am getting the same line on a new file.
Does anyone have suggestions as to what might be causing this and how to fix?
I greatly appreciate any information you can give!
