ir 1022 or ir1022i no display
  • eurokris
    • 120
    hi
    ir1022 and ir1022i after download firmware display black .
    pls advice me how to recover back.
    thanks
  • teckat
    • 16083
    Re: ir 1022 or ir1022i no display
    Originally posted by eurokris
    hi
    thanks
    u mean a iRC1022/1022i ????
    what procedure did u follow ?
    • HELIO240
      • Jan 2011
      • 137
      hi
      thanks
      Which procedure you used to occur the display black, what do you do? Say so we can help you.
      • eurokris
        • 120
        im using sst to download the firmware.after download firmware off and on machice.
        display black only.pls advice me
        thanks
        • teckat
          • 16083
          thanks
          answer my question !!!!!!!!!!
          what is the exact model ??? what version firmware did u use ????
          what procedure did u follow ??????????????????????????????????????????????????? ?????????????????????????????????????????????????? ????
          • eurokris
            • 120
            ir 1022/1024 black and white mc not color model.
            • teckat
              • 16083
              what procedure did u follow ? for this firmware install ???
              what ver. of firmware was installed & why ???
              check the image processor
              • ernesto
                • Oct 2011
                • 430
                hi
                thanks
                hi,
                if you download first system before "boot", imageprocesor is gone you have to change it. when you update this model firstly you must download "boot" and secondly "system".
