Ir7095 cassettes
  • jiongpao
    • May 2009
    • 414
    Ir7095 cassettes
    Hi, today we service another ir7095 machine. The problem is cassettes 2,3 and 4 unable to pull the paper up and it show jam. It can detect the paper but it seems pick-up, feed and separation roller doesn't function at all. Cassette 1 running fine. Base on the jam code 102, 103 and 104 I did cleaned all the pick-up sensors but no cure. Is there anything that I miss out or any clues? Thanks
  • jiongpao
    • May 2009
    • 414
    Re: Ir7095 cassettes
    And sorry for accidentally double post.
    • spectraindo
      • May 2008
      • 313
      Check the Timing Belt at the Rear of the machine maybe its broken.
      • mpsinc
        I have the same problem going on..... Can you point me in the right direction as to where the timing belt would be?
        Thanks in advance!
        • spectraindo
          • May 2008
          • 313
          The timing belt is located at the rear of the machine, you must take off the HVT and the Waste toner plate.
          • teckat
            • 16083
            Thanks in advance!
            READ---------Timing Belt.pdf
            • Simons
              • Jun 2008
              • 490
              I have one with no pick up on drawer 1 and others work. Mine has the page count to justify a new belt and gears. Funny my problem is with drawer 1 and yours works!
              • jiongpao
                • May 2009
                • 414
                The problem solved. The cassette timing belt at the rear of the machine was felt out of it position and that causing it cant pull the gears of cassettes 2,3 and 4 when the gear motor is running. Probably when we move that machine from other place to another theres an impact during loading.
