service ir 5570
  • btm_ami
    service ir 5570
    i need service manual ir 5570 and error code
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: service ir 5570
    Contact Paul at manuals4you
    • bojans
      • 1313
      Re: service ir 5570
      Or you can post your problem and error code, someone will help you.
      • HELIO240
        • Jan 2011
        • 137
        Re: service ir 5570
        tell us what the problem here and someone can help you.
        • gensys
          • Jan 2011
          • 323
          Re: service ir 5570
          You can find all answers here - it is necessary to look well
          The Road will be Mastered by >>> the Going...
          • btm_ami
            Re: service ir 5570
            error 000004-0010 show in screen
              • 16083
              Re: service ir 5570
              ?-1. are u a tech
              ?-2. if not>call for a trained tech
              Fuser codes are for trained techs to investigate-
              service mode>COPIER>FUNCTION>CLEAR>ERR
              unusual sub-code to have
              0010=Check the rear fixing connector for bent, damaged or defective pins.
              E004 there is an error in the IH power supply/IH control mechanism.
              E004 The IH power supply is faulty/the IH control mechanism is faulty.
              After correcting the fault, be sure to reset the error.
              (COPIER>FUNCTION>CLEAR>ERR)
              power off/on printer
              sub codes:
              0010-The power has been turned off and then on
              without resetting the error.
              0101 There is a mismatch between the input voltage
              and the IH power supply ID. Replace the fixing heater power
              supply with one designed for the country of installation (voltage).
              0102 The IH current is faulty. (current leakage) - Check the connector
              for any fault in connection.
              - Replace the fixing heater power supply.
              - Replace the DC controller PCB.
              0103 The IH current is faulty. (no current)
              0104 There is an IH over-current.
              0105 The IH input voltage is too high.
              0106 The IH input voltage is too low.
              0201 At power-on (or, when IH is at reset), the IH
              control mechanism is not in an initial state.
              0202 At IH start-up, the IH control enable flag is not set
              within 1 sec after the start flag is set.
              0203 With IH at rest, the IH control flag is not released.
              0204 The 12-V power supply (IH relay) is identified as
              being off.
              0205 At IH start-up, the PWM_ON data is faulty ('0' or
              'FFFF').
