iR5000 e740 - 002
  • bakaoni666
    • Mar 2010
    • 56
    [Misc] iR5000 e740 - 002
    Can i use a usb to parallel adator cable to connect the machine...?
    Need sst ver 4 and the newest firmware iR5000d...please
    novel_runner@yahoo.com
    thanks
  • jiongpao
    • May 2009
    • 413
    Re: iR5000 e740 - 002
    e740-002 The LAN card is faulty. The main controller PCB is faulty. A MAC address is found to be faulty.
    i never try using usb to parallel adapter to load firmware but using it for printing purpose it will run.
    • acusso1234
      Tecnico
      • Dec 2008
      • 250
      Need sst ver 4 and the newest firmware iR5000d...please help
      I think no, cause the original usb to parallel from Canon is a dedicatet tool (some crossed wire inside).
      But I can be wrong as I've worked on this model years ago..
      ... In the minute that you're thinking of giving up, think about why you lasted so long ...
      • bakaoni666
        • Mar 2010
        • 56
        my pc has no parralel port... any idea?
        • acusso1234
          Tecnico
          • Dec 2008
          • 250
          Did you already tried the internal ck disk from the service mode of the machine? It takes lots of time but I remember that sometimes it worked for me..but if the HD is bad...
          • gensys
            • Jan 2011
            • 323
            Any ideas...............
            The Road will be Mastered by >>> the Going...
            • bakaoni666
              • Mar 2010
              • 56
              Still
              I tried to clone Hdd but it came with E602-004 and E602-001.
              Does anyone have SST ver 4.42 and the latest firmware please..
              • bakaoni666
                • Mar 2010
                • 56
                mcont 81.03
                boot 23.44/26.33
                Still Error...
                What shoul i do..
                  • 16083
                  mcont 81.03
                  boot 23.44/26.33
                  Still Error...
                  What shoul i do..
                  are u sure u have a 5000d ???
                  E740 code on the copier LCD screen
                  The copier must have the new style Ethernet Board PCB (NIC) installed. If the copier's firmware (system software) is not up to date, an E740 code will be displayed when the new style NIC is installed in the copier.
                  Ethernet Board PCB (NIC):
                  Original Style - part number FG6-5964-000
                  Newer Style - part number FG6-9898-000
                  Newest Style - part number FM1-0196-000
                  With this new NIC, there are some newer firmware versions needed or the E740 code will still display. This NIC CANNOT be installed on the old style iR5000. Here are the versions needed for FM1-0196-000:
                  Engine System Software
                  imageRUNNER 2200/2800/3300 42.03
                  imageRUNNER 3300i 25.02
                  imageRUNNER 2220N/2220i/3320N/3320i 34.05
                  imageRUNNER 5000d/6000 81.03
                  imageRUNNER 5000i 9.01
                  imageRUNNER 5020/6020 55.06
                  imageRUNNER 5020i/6020i 55.06
                  imageRUNNER 7200 82.04
                  imageRUNNER 8500/85 82.04
                  imageRUNNER 105 82.04
                  Minimum firmware versions to recognize the New Style Ethernet Board (FG6-9898-000)
                  Model(s): MN-CONT (system software): BOOT-ROM:
                  imageRUNNER 2200 / 2800 / 3300 41.01 or higher 23.40 or higher
                  imageRUNNER 3300i 24.02 or higher 23.40 or higher
                  imageRUNNER 2220N / 2220i / 3320N / 3320i 33.01 or higher 24.42 or higher
                  imageRUNNER 5000 19.02 or higher 14.54 or higher
                  imageRUNNER 5000d / 6000 74.02 or higher 23.40 or higher
                  imageRUNNER 5000i 44.02 or higher 23.40 or higher
                  imageRUNNER 5020 / 5020i / 6020 / 6020i 54.03 or higher 24.42 or higher
                  imageRUNNER 7200 / 8500 / 85 / 105 81.02 or higher 23.40 or higher
                  ON P PRINT>>>>>Check the FIRMWARE VERSION:
                  Flash the machine and all accessories to the latest system software. Check under SERVICE MODE>COPIER>DISPLAY>VERSION that all the firmware has been updated as desired. Mismatches and outdated firmware versions may be incompatible
                  The new-type Ethernet board cannot be recognized when it is used with earlier versions of System
                  Software other than the following:
                  imageRUNNER 5000: System Software Version & 19.02 BootROM Version 14.54 & later
                  imageRUNNER 5000D/ 6000D: System Software Version 74.02 & BootROM Version 23.40 & later
                  imageRUNNER 5000i: System Software Version 44.02 & BootROM Version 23.40 & later
                  imageRUNNER 5020/ 5020i/ 6020/ 6020i: System Software Version 54.03 & BootROM Version 24.42 &
                  later-
                  Without these System Software & BootROM upgrades, a symptom of E740 will occur.
                  When replacing an old style Ethernet Board PCB on copiers with the new type Ethernet Board PCB or installing a new Multi PDL Printer Kit, please be sure to upgrade the System Software, and Boot-ROM to the above version levels or later respectively.
                  You will NOT have the ability to enter the IP Address and E740 code will occur if the
                  System Software & Boot-ROM are not upgraded to at least the specified versions above.
                  How to identify the old and new Ethernet Board PCB assemblies:
                  Either of the following part numbers is silk-screen printed on the PCB.
                  Old Part: FG3-1186*
                  New Part: FG3-3326*
                  * These part numbers are manufacturing numbers only and are NOT valid for ordering.
                  Pressing the Device Config. key causes the following version and device information to be indicated as in service mode:
                  - Main board version (part revision number of the Main Controller PCB)
                  - Controller version (MN-CONT/BOOT-ROM/DC-CON)
                  - Scanner version (R-CON/FEEDER)
                  - Finisher version (SORTER/SDL-STCH)
                  - Device information
                  • bakaoni666
                    • Mar 2010
                    • 56
                    I'm sure..it is iR5000d. Sorry I'm so confuse so i post this in two places.
                    Thanks the machine works now...
