CANON IR C5180 H1 FIERY
  • printerjohn62
    • Sep 2011
    • 27
    dO YOU HAVE TO USE THE H1 FIERY OR CAN YOU JUST USE THE CARD IN THE PRINTER.
    THANKS
    JOHN
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: CANON IR C5180 H1 FIERY
    Don't need fiery.
    • printerjohn62
      • Sep 2011
      • 27
      Do i set the ing con to 0? Anything else i need to do?
      john
      • zoraldinho
        • Mar 2008
        • 5018
        If your model 5180i you have printer card already installed.If you have model 5180 need imagePASS-H1 or Color Network Printer Unit-H1.
        • charm5496
          • 2387
          THANKS
          JOHN
          if you want to be able to print to the device without using the H1 your machine will have to have the UFR/PCL printer kit N2 installed in its place.
          The 'I' model comes standard with the N2 printer kit from factory.
