ir4570
  • cleardata
    • Jul 2011
    • 137
    ir4570
    hi to all,
    this is my first time to handle ir4570 and the machine displays "press the open button, and open the main unit right cover. then, remove the jammed paper. (when finished, close the cover)".
    at the bottom is says "the paper has jammed".
    but i don't see any paper even a very small one.
    what should i do? please help...
    thank you.
  • mramlawi
    • Jul 2011
    • 838
    Re: ir4570
    friend make sure that the paper is jam it never fails when it said there's jam look at the right cover when the paper enter the duplex unit some times u couldnt see the jam paper so make sure that there's no paper .
    waitiing ur reply
    Distinguished road makes you jewel in rough
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: ir4570
      When you have jam on this model,after removing paper must open and closed cassete,main and lower door.If you are a tech,jou can post a jam code.
      • cleardata
        • Jul 2011
        • 137
        Re: ir4570
        i was looking for a jam code but there is no jam code.
        i did open and close the cassete, main and lower door.
        • cleardata
          • Jul 2011
          • 137
          Re: ir4570
          found no paper but the sensor was full of toner because there was toner spill from the drum unit because the tip of the recycling "paddle" (don't know if this the right term for it) is broken. thank you.
          • jiongpao
            • May 2009
            • 414
            Re: ir4570
            clean the sensor first then. Its better to take out the sensor and clean it may be the toner became solid and stick on the sensor around
