irc 3180 E070-003
  • eurokris
    • 120
    [Error Code] irc 3180 E070-003
    hi all
    irc3180 came out eror E070-003.change all set itb assembly and dc con also same eror code.
    pls advice me
    thanks
  • gensys
    • Jan 2011
    • 324
    Re: irc 3180 E070-003
    Originally posted by eurokris
    hi all
    pls advice me
    thanks
    When the ITB HP Sticker [A] attached to the backside of the Transfer Belt (P-1) becomes dirty, incorrect detection
    may be performed by the ITB HP Sensor [B], causing the following errors occur.
    Read This............>>>>>
    If the Transfer Belt [A] is largely displaced toward the front side of the machine, the Transfer Belt [A] may break to
    cause E070-0003 (ITB HP detection error).
    Read pdf
    The Road will be Mastered by >>> the Going...
