Ir4570 feeder adjust
  • mramlawi
    • Jul 2011
    • 838
    hello ,
    canon IR4570 i need information how to adjust the feeder of it how to adjust the margin up and down left and right
    also if how can i adjust the margin of the casette in program .
    Distinguished road makes you jewel in rough
    Re: Ir4570 feeder adjust
    The margins on the feeder can be adjusted with service mode > Feeder > adjust > doc stop.
    This will move the image in the direction of the arrows
    - if the image is displaced to the leading edge, decrease the setting.
    - if the image is displaced to the trailing edge, increase the setting.
    unit of adjustment: 0.1 mm
    The top and bottom margins for each cassette can be adjusted in service mode level 2 > Copier > adjust > misc C1/2/3/4-ADJ-Y
    C1/2/3/4-
    ADJ-Y
    Entering a horizontal registration adjustment value for Cassette 1/2/3/4
    Enter the horizontal registration adjustment value for Cassette 1/2/3/4.
    Enter the laser writing start position on the paper picked up from Cassette 1/2/3/4,
    based on the registered value.
    An increase by +1 enlarges the front margin by 0.1mm.
    <Note>
    When clearing RAM of the DC controller PCB or replacing the PCB, enter the
    service label value.
    • mramlawi
      • Jul 2011
      • 838
      Thanks man
