Canon ir 2016 - e003 error
  • savi0r
    • Sep 2010
    • 363
    Hi all. I have this problem with a Canon ir 2016. I changed the fixing film, and after about 2 days, it started giving e003 error. I'm really confused about one thing. The connector from the fixing film assy and the power supply really seems to not make perfect contact. I'm sorry about my explanation or my english, so i attached a photo of the gap that doesn't seem right. Please feel free to give any advice about how i can fix this problem. Thanks
  • mramlawi
    • Jul 2011
    • 838
    Re: Canon ir 2016 - e003 error
    Man u just change the fixing film or u mean you change the fixing film unit ?
    Distinguished road makes you jewel in rough
    • savi0r
      • Sep 2010
      • 363
      Just the fixing film. The old one was broken. And i'm not sure if the e003 error is caused by an imperfect contact, if that is the case in the picture i attached.
      • mramlawi
        • Jul 2011
        • 838
        okay man it happened with me in few days and it was the fixing film broken ,so i changed it and also it gives me same error so i changed the fixing film asseambly. and after that everything goes okay so change the fixing asseabmleee
        • savi0r
          • Sep 2010
          • 363
          I know changing the fixing film assy would solve my problem, but i am trying to fix mine. How about the photo i posted? Does that connector go all the way on the "+" of the assy or that gap in the photo must be there? If this isn't the problem, i am planning to clean the fixing film assy again and change the vaseline. Waiting for your ideas.
          • livancicm
            • Sep 2008
            • 96
            all the way
            • V-P
              • Apr 2011
              • 679
              Usually vaseline is used for "OTHER KIND" of fixing units, but you can try ...
                • 16083
                hi all. I have this problem with a canon ir 2016. I changed the fixing film, and after about 2 days, it started giving e003 error. I'm really confused about one thing. The connector from the fixing film assy and the power supply really seems to not make perfect contact. I'm sorry about my explanation or my english, so i attached a photo of the gap that doesn't seem right. Please feel free to give any advice about how i can fix this problem. Thanks
                [ATTACH=CONFIG]13291[/ATTACH]
                fm2-3345-000 1 fixing assembly 120v
                fm2-3352-000 1 fixing assembly 230v except cn
                fm2-3328-000 1 fixing assembly 230v cn
                fm2-3346-000 1 fixing film assembly 120v
                fm2-3353-000 1 fixing film assembly 230v except cn
                fm2-3329-000 1 fixing film assembly 230v cn
                • savi0r
                  • Sep 2010
                  • 363
                  Siliconic vaseline MUST be used. Otherwise, the film may not rotate or it's lifespan will be very short. I'll rebuild the fuser one more time today and hope all goes well. Thank you all for your advice. It helped.
                  • savi0r
                    • Sep 2010
                    • 363
                    Hi all. First of all, thank you for your support. Second, i found the problem. It was an imperfect contact (the one showed in the photo in the attachement) and it cracked my heating element. Teckat, thanks for the part numbers, but here in romania, the fixing assy costs about 600 euros. So it's very expensive. I found just the heating element at about 40 euros. Thank you all again for your repplies.
