Machine start with standard canon start up line,come to the middle and reboot again.Second start up is the same then freeze.I swap all dimms,power supplys,main controller and dc controllers.
Working only startup with 28 and nothing else.I don't have another hdd to try.This one can't format because SST showing:
Timeout error at RcvRes(). 1stResTO
<<< FileName >>>
HDDFormatALL:C:\ServTool\iAC7055\HDFormat\XXxxv061 9\iAC7055-XXxx0619-HDFormat.ift
Module : SendFile() – 4
E-221
Also can't upgrade:".Can not create file on disc."
<<< FileName >>>
E-221
