Canon ir-7095 dev tank blade adjustment
  • copycentre
    • Jun 2009
    • 19
    Hello all,
    We have a Canon ir-7095 which is producing light, uneven copies (some parts are darker than others). I've hoovered out the dev tank, installed new (genuine) toner, and changed the coronas with no result. It seems like I need to adjust the dev tank doctor blade; does anyone know how?
    Is there a function in service mode for the adjustment?
    Thanks in advance for your kind help,
  • vigour
    • Aug 2010
    • 1038
    Re: Canon ir-7095 dev tank blade adjustment
    no. just a screwdriver ( Bad Idea)
    turn off potential control then:
    Adjust the height of your primary coronas.
    start with door spec.
    • copycentre
      • Jun 2009
      • 19
      Thanks, I'll give it go..
      • jiongpao
        • May 2009
        • 413
        developer cylinder may cause this problem too, make sure u didnt drop the dev cylinder or developer unit
        • mramlawi
          • Jul 2011
          • 838
          i have the Same problem but on IR8500 i changed the cyliander 2 times and got same problem,i changed the corona's also still the same ,didnt appear the problem in 2o copies,i appear when start to copy on it above 100 copies,dont know what to do really :S i get the machine back to my workshop i also changed the HV Board and the Hopper Clutch's !! :S
          its really worst problem i got
          P.S : i always use Genuine Toner
          Distinguished road makes you jewel in rough
