ir3035i toner not sticky
  • mfcopier
    • Jun 2025
    hallo everybody, i have facing the problem my client machine ir3035i, toner not stick on paper, i have already replaced the film and pressure roller but the result still same, what prob. that?? i should be replaced the heater element ?
  • vigour
    • Aug 2010
    • 1038
    Re: ir3035i toner not sticky
    what is your fuser temp?
    Is the nip width within spec.
    Are you using regular copy paper?
      • 16083
      Did u pay attention to the position and the
      orientation of the insulating bush.
      Do not touch the screw [1] used to keep the fixing
      assembly in place. Turning the screw will change the
      pressure of the fixing assembly, which cannot be
      adjusted in the field,
      necessitating the replacement of
      the fixing assembly.
      In service mode level 1 > Copier > Display > Analog
      check FIX-C temp and FIX-E temp-----------report back
      did u check NIP Pressure
      COPIER > FUNCTION > FIXING
      NIP-CHK Making output for measuring the fixing nip width automatically
      <Operating procedure>
      1) Register Plain Paper or Recycled Paper for the manual feed tray.
      (User mode: Setting Common Specifications>Registering Paper Type).
      2) Place plain paper or recycled paper of the A4 (LTR) size on the manual feed tray.
      3) Select this service mode and press the OK key (to feed paper from the manual feed tray).
      4) The fed paper is held once by the fixing roller and ejected after about 10 seconds.
      5) Check that the nip width of the ejected paper conforms to the standard.
      Note: This machine does not allow nip width adjustment. This item is used for nip width checking only.
      Check if the door actuator has become displaced, not allowing the right side door to close properly.
      The result will be> the fixing film is not properly pressured, resulting is poor fixing and streaked copies. Check the actuator on the right side door to be sure it is positioned properly, as shown in the below photograph.
      • mfcopier
        ok.. thank you so much for your supported, i will try and check first with follow your guide.., and report back soon, i hope will be sucsess tq.
        • mfcopier
          Originally posted by vigour
          what is your fuser temp?Is the nip width within spec.Are you using regular copy paper?
          the fuser temp is normally, is become 200'c when copy progress. i not do the nip chk i using the new paper...but the pressure screw have touching.... how to standard back?
            • 16083
            u may need to do a trial and error on this/ if u can't match up the red glue position of screw
            • mfcopier
              i cant solve the problem..., i make adjustment the pressure screw to red marked but the result better than before....,toner cant melt on paper at the right side/upper side of paper, the fuser like not tight at gear area/ right side so the poor result come from that are..., how to do??? any suggestion???
                • 16083
                set that screw back to spec position/
                then remove film/pressure roller> an re install both/ back in and test
                • mfcopier
                  ok.. problem solved already..., thank you everybody.., always need your support especially you (teckat).
                  best regards.... mfcopier.
                    • 16083
                    thanks,
                    how did u get it to perform on spec ??
