Ir 9070 Error 602
  • mindhunter
    • May 2008
    • 141
    Ir 9070 Error 602
    Hi .
    I change My Copier HDD and Install A new HDD. And Copier Show Me Error 602.
    Is there Any Instruction that Can Help Me?
  • vigour
    • Aug 2010
    • 1038
    Re: Ir 9070 Error 602
    what is the subcode?
    did you install new system software?
    • teckat
      • 16084
      Originally posted by mindhunter
      Hi .
      Did u first Format the new HDD using the 9070 Format firmware using SST ???
      Did u load the iR9070 Firmware back in the HDD - using the Canon SST ????
      where did u get this HDD ? is it compatible for this printer ??
      • mindhunter
        • May 2008
        • 141
        the hdd is the same as other Ir9070 Copiers. But I Dont know what steps I should to do .
        I didnt Format and I didnt using System Software and sst but i have system software and sst . Could you please Give me Instruction that i have to do ?
        • teckat
          • 16084
          best bet> call for a trained tech
