Canon IR c5185 E225 0001
  • manuelubau
    • Aug 2011
    • 62
    [Error Code] Canon IR c5185 E225 0001
    Hi,I have a Canon IR c5185 that shows error E225-0001. I am pretty sure it is something about the scanning lamp because when I turn on the machine, the lamp keeps turning on and off for some time and does not move at all, then the machine shows the error. I have replaced the lamp, the PCB and cleaned most parts close to the lamp and the scaning unit. Anyone knows what else I should look into? I really need help,Thanks a lot!Manuel Ubau
  • teckat
    • 16083
    Re: Canon IR c5185 E225 0001
    Check or Replace the ribbon cables that go from the Reader Controller PCB to the Interface PCB. The two cables come together as one part attached to a plate. The cable part number is as follows, item 9 circled below:
    Color imageReader F1 = FL2-4857-000
    Duplex Color imageReader G1 = FL2-7976-000
